jane93's avatar
jane93
Starter battery drain
Installed new starter battery and still drains to dead in a day. Entry step will not stay out in any setting. Ohmmeter measures 2.6 ohms in series of positive terminal. Have checked all fuzes and battery disconnect switch. Replaced relay in overhead passenger side compartment. .. unsure of its function but was not engaging and was hot to touch. Will start from coach transfer over switch. Is there some entry step mechanism to check?
  • Trik-L-Start will solve the issue.
    If not plugged in... 100w of solar should be added to the house battery.
  • allbrandauto wrote:
    ANYTHING MORE THAN .01 AMPS IS TO MUCH
    You sure you don't mean .1 amps (100 mA)? My dash radio pulls .045 Amps (45 mA) just by itself to retain its memory.
  • A resistance test between terminals unfortunately doesn't help much. There are a lot of parallel loads on the battery which would make a ohms reading difficult to pin down. An amp test will help some to give you an idea of how fast the battery will drain down. Either way finding the load isn't always a simple process. More or less you're going to need to start disconnect stuff or pulling fuses and do a current test over until you find the problem.
    Concerning the steps. They work pretty much the same as power windows in a car. No micro switches to sense position and such. The step controller works by sensing how much current the motor is demanding. Once the current reaches a preset level the controller will shut off power but there's a catch. When the voltage to the system drops the current required to do the same amount of work will increase. The catch is the controller only senses current. So a low battery will screw things up with lower voltage. Also a poor ground contact will reduce voltage and increase current confusing the controller even more.
    So hunt down the load that is killing your battery first then check your steps out for proper operation. Not sure what the relay you replaced was. Maybe the TV kill switch that will prevent you from watching TV when the coach is going down the road.
  • YOU NEED TO CHEAK BATTERY FOR DRAIN DO SO BY DISCONNECTING ONE BATT. END AND HOOK A AMP METER BETWEEN THE 2 CABLES ANYTHING MORE THAN .01 AMPS IS TO MUCH IF MORE AMPS THAN DISCONNECT WIRING TO STEP MOTOR SEE IF DRAW IS GONE IF NOT PULL FUSES TO YOU FIND THE DRAIN
