โFeb-22-2019 12:52 PM
โApr-28-2019 08:38 AM
ronfisherman wrote:I have had a steel wheel crack and leaking air. Was glad to then justify moving to aluminum.
Here is picture of a cracked aluminum wheel.
Tire was still inflated. Wheel had to be replaced.
My MH had Aluminum wheels. Lot less problems than SS liners.
โApr-28-2019 05:20 AM
Gjac wrote:
To me the main advantage that has not been mentioned yet is the manufacturing process and tolerance. The steel wheels are stamped in a die and may be with in .030 of an inch. The Al wheels either cast or forged are machined within .005. This makes for a wheel that is more accurate and easier to balance at high speed using less weight. Having said that, having hit a big pothole with mine it is easier to straighten a steel wheel with a hammer without cracking the wheel because the steel is more ductile that a cast Al wheel which is more likely to crack. The forged Al is stronger than cast and more ductile than cast but not as dutile as the stamped steel. The Al wheels look nicer but for me when I consider the cost vs performance benefit I would stay with the steel wheels.
โApr-27-2019 07:39 AM
โApr-26-2019 03:46 PM
โFeb-24-2019 08:47 PM
โFeb-24-2019 07:01 PM
โFeb-24-2019 06:24 AM
โFeb-24-2019 04:44 AM
โFeb-24-2019 03:28 AM
โFeb-24-2019 12:38 AM
โFeb-23-2019 03:46 PM
ronfisherman wrote:Your list outlines what I always understood, why the inner two rear wheels remain steel when using Alcoa wheels. If another brand can have all alloy in back, then I wonder if the alloy wheel is thick enough for weight of a motor home. I once found pictures of alloy wheels that developed cracks but I can't find them now.
Some things to check when putting 2 aluminum wheels on each side of rear axle.
1. Are the mounting studs long enough for the thickness of 2 aluminum wheels?
2 . Does pilot hub of axle stick out far enough to properly locate wheel on center?
3. Will 2 aluminum wheels affect location of outer wheel be offset to far?
โFeb-23-2019 02:21 PM
โFeb-23-2019 01:25 PM
โFeb-23-2019 10:30 AM
ron.dittmer wrote:
This topic interests me.
I have a 2007 E350 chassis with stock steel wheels in great condition. I also have stainless wheel covers. I will be replacing the tires before our next big trip and figured it's the right time to upgrade to alloy wheels.
After some research, I am most comfortable with the Alcoa brand, so when it's time, I will be buying that brand. Alcoa offers a few different finishes on their wheels. Since our rig is stored indoors most of the time, and we travel during non-winter salt-free conditions all the time, I will be buying the ones with the Dura-Bright finish HERE, currently priced at $1399.00. Their plain finish wheel package costs $200 less.
I have yet to decide what valve stems to buy. I don't want "extensions", just one-piece valves that stick out only as far as needed for access. I would appreciate any tips on "best valves" to consider for the thicker allow wheel material.
I am buying the alloy wheels primarily for "The Look", but also hope to improve the ride through less un-sprung weight.
