Fishinghat
Apr 22, 2015Explorer II
Steering Box Slack Adjustment
I have a 1993 HR Navigator on a Spartan Mountain Master chassis. My steering gear has an adjusting screw on the side, which I assume is to take out any looseness or slack in the steering. Does anyone know what the settings are? That is, how far do I back off the center screw after it makes contact? I'm assuming something like 1/2 turn would be enough, but I don't want to experiment only to have the steering lock up on me at a very inappropriate time.
I've had a frame shop check the front end and the alignment, and all is within specifications. I've even raised the front end up and checked for any worn or loose parts and everything seems tight and in good shape. (I do the lubrication myself, so I know all the zert fittings have been serviced.)
