- BordercollieExplorerMaybe pour Metamucil down the toilet?
- TonijimExplorerTo J-D - apparently a Four Winds (Thor) feature on some models. The passenger side valve holds the black water until both valves are released. We open the traditional dual valve black (driver's side) then the passenger side, allowing the cross camper pipe to release. We reverse when we close the system. Caused some confusion when we first used it as the rig was a new to us 2010. We'll try lubricating the passenger side valve rod when next we empty. As long-time rv'ers say - it's always something.
Jim - garyhauptExplorer
Tonijim wrote:
Thanks for the thoughtful responses. I should have said that our rig is a 33' Four Winds Freedom Elite with two valves to empty the black tank - one directly on the passenger side under the toilet and the other on the driver's side in tandem with the grey tank valve. The sticky valve is under the toilet. Don't know whether that changes any responses. Thanks again.
Jim
Nope..lubricate that rod.
Gary Haupt - PSWExplorerThis is the first RV I have owned with the Sanicom system and it includes a flush valve for black and one for gray and a water hose connection. I love it and it seems to really help the sticky valve situation.
Before, I have used the old coconut oil trick in the tanks when the rig is going to not be used a while and it seems to help keep the sticky or leaking valves in better shape.
I have thought about flushing the tanks and then pouring about five gallons of hot soapy water into them and letting it set for a while.
As to the rods or cables (I have had both) I just clean them ocasionally and lubricate. I use a grease the garage door repair guy gave me to lubricate the rollers on the door. It is great stuff and is a light white lithium grease.
Anyone tried to help valves with a few gallons of hot water in the tanks?
Paul - j-dExplorer II
Tonijim wrote:
...33' Four Winds Freedom Elite with two valves to empty the black tank - one directly on the passenger side under the toilet and the other on the driver's side in tandem with the grey tank valve...
Perplexingly fascinating! Am I correct in thinking the two valves are "in series" where both have to be open to dump out the sewer hose connection, but you could leave one open and then dump from the other? - dakdaveExplorerwhen mine got sticky and hard to pull i lubed the pull rod with plumbers grease,Feed it up nicely,now lube it regularly.smear on rod and work back and forth a few times
- TonijimExplorerThanks for the thoughtful responses. I should have said that our rig is a 33' Four Winds Freedom Elite with two valves to empty the black tank - one directly on the passenger side under the toilet and the other on the driver's side in tandem with the grey tank valve. The sticky valve is under the toilet. Don't know whether that changes any responses. Thanks again.
kevden wrote:
The flush valve on our toilet had been sticking. I sprayed silicone into the toilet and the valve works better than new. Maybe you could spray some up into the drain valve from the slinky hose connector? Or, pour a bottle of silicone detailing/protectant spray into the tank?
Not wishing to create waves...but I am thinking that pouring some into the tank itself isn't going to lube the cable or rod...they are outside the tank itself.
Gary Haupt - MocoondoExplorer IISilicone spray works for a while, but if you don't want to keep treating it, get a toilet brush with a long handle and a cheap can of grease. Every once in a while, run the greased toilet brush up your termination valve and give it a few turns around each valve when they are open. You can thank me later.
- kevdenExplorerThe flush valve on our toilet had been sticking. I sprayed silicone into the toilet and the valve works better than new. Maybe you could spray some up into the drain valve from the slinky hose connector? Or, pour a bottle of silicone detailing/protectant spray into the tank?
About Motorhome Group
38,721 PostsLatest Activity: Apr 19, 2023
