Danpaine's avatar
Danpaine
Storing with jacks up, or down?
Hi there, Folks. Unfortunately, I'm in a position where I have to keep my rig at a storage facility, on gravel. The site isn't bad, but not...quite...level, and water is creeping in a slide.
Can anyone share some advice on storing the rig with the leveling jacks down? Good or bad? I have been using standard leveling blocks, but that can be a hassle, especially by myself. My main concern is the jacks getting 'stuck' in the down position. What I was thinking is that I can move them up and down during one of my weekly checks on the rig.
Thanks in advance for any input.
  • We store ours “jacks down”! I like the idea of keeping the unit level ( our air bags will slowly leak down) as well as, “unloading” the already “very taxed” springs! memtb
  • Gjac's avatar
    Gjac
    Other than leveling your RV there is now advantage to storing it with the jacks extended. Trucks, cars, farm equipment all set for months or years on the vehicles suspension. Leaving them extended exposes the pistons to snow and moisture. As Bobndot posted wood blocks or gravel would be a better solution to level the RV. I use wood to level and to keep the tires from sitting in the mud.
  • water is creeping in a slide.
    Can you turn the rv around in another direction so the water sheds away from the slide ?
    Wood blocks under the tires ? Just make them bigger than the tire footprint as to not damage the tire.
    Would it be possible, since its on gravel to add a bag of your own gravel under the tires to raise that side.
  • Put the jacks down sufficient to take pressure off the tires and suspension. Mice will not climb a jack leg (regardless of how powered), no traction. In addition, increase tire pressure by 20% over normal to reduce flat spotting and adjust back down when you lower the unit.
    Jack pistons only need to be clean, no grease required.
  • way2roll wrote:
    Mike134 wrote:
    Up. 4 less paths for mice, let them make the easier climb at your nextdoor neighbor.
    Wouldn't mice climb tires easier than a greased, slippery, hydraulic jack?
    For sure but the OP didn't say what type
  • Up. 4 less paths for mice, let them make the easier climb at your nextdoor neighbor.
  • Lots of folks leave their jacks down with no problem. Wipe them down with the appropriate lubricant to prevent rust etc, and should be good. Probably a good idea to exercise them periodically though.
    Why you are getting water in a slide is another issue and one I would I would try and figure out.
About Motorhome Group
38,718 PostsLatest Activity: Nov 06, 2018
