I put sumos on front of 2016 winnebag adventurer 38q and love them. Thinking about putting solos on to replace rear bump stops as i can't put the larger sumos on rear. Anybody done this?
Yes. it does stiffen up the ride a bit. But it also makes you feel a little more in control of the rig with all four. I replaced the bump stops. It would have made the ride too stiff if I had placed the larger sumo springs on the rear. You will still feel sway, but not to the degree that it was before. I will probably still go with a larger auxillary sway bar on the rear later.
