richbes's avatar
richbes
Sumo vs Timberns
I have a 2015 Itasca 27N. I would like to improve the ride. Looking at Sumo Springs or Timberns. Anyone have experience with either or both. Thanks.
  • On a MH, the Timbrens and Sumos will be preloaded at normal ride weight. They will eliminate the harsh bump that happens on normal road conditions, as they replace the bump stops, that the springs hit. I have Timbrens, both have a lifetime warranty. The Sumos are urethane, and the Timbrens are rubber. Both do the same thing, increase spring rate. Most people report a better ride and handling.
  • I have Timbrens installed and they work just fine when I'm hooked to the 5th wheel. They ride about an inch from the axle tube so they only come in to play when I'm loaded.
