surge protectors
mammothsteve
Hello all. Recently bought a DP and am curious to know about surge protectors. I have RV'D for the past 40 years with everything from a cab over, a class C to several 5th wheels. In all those years, I never had a surge protector. I'm reading posts from several people that have had issues with these devices.
My question(s) are thus:
Are surge issues commonplace? Is it REALLY necessary to have one? Are RV park spikes that frequent or is this just a sales pitch to spend $300+?
If it is an issue, is a portable or hardwired unit better that the other?
Thank you for any response. All the best!
42 REPLIES 42
ArchHoagland
I've repaired computer hardware for 40 years and I don't use a surge protector, now will I ever.
Low voltage is the real culprit and it will take out your air conditioner fairly quick. I monitor our 120 volts and if we drop to 105 off goes the air conditioner.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
msturtz
Not only do we have a surge suppressor we also use an Autoformer which will protect the coach. It will boost the voltage in if it is low as is common in summer when everyone is running their AC. It the voltage is less than 117VAC it will boost the voltage back up to 115 VAC. Low voltage will damage RV systems.
FMCA member
kuzined
Been rvin 13yrs. Never had a problem. So....4days ago at 3 in the morning, guess what!Yup. Took out the fridge, convection micro, water cooler, beer fridge and a couple of small items.Only thing that saved the laptop is the little surge protector in the multi-plug cord I was using.Smell of burnt wire woke me up.Inside of plug-in was black and burnt.Rig is staying in Arizona....Im going home to Canada in a couple of days.Will be coming back in the fall with a surge protector for sure.
hershey
I've used one for over 11 years fulltiming. I have no idea if its necessary or not. If it did its job, I never knew it. Perhaps I need new underwear?
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
et2
We have one and more than twice has shown bad wiring before even hooking up. Now the new mh has a hard wired one. But I still use the post as well. So I wear two pairs of underwear. Never a had a problem, at least the post will trip first
ForestRiverTeac
It's not all about a surge. It's also about low voltage -- low enough that, over time, it could ruin your AC unit.
I wouldn't have an RV without an EMS system. It's saved us from unknowingly running our AC on low power -- actually shut us down.
Weighing the cost of an EMS system against the cost of repairing/replacing the everything electrical in my rig is a no-brainer. And for what most of us pay for our motorhomes, another $300 shouldn't be an issue.
On the road and happy with Jed and Tilly, my four-legged camping buddies
2015 Thor A.C.E. 30.1
3oaks
Surge protectors are like insurance policies. Don't really need them, but should accident or in this case, an electrical abnormally, occur, you wish you had had the protection.
sailor_lou
The better surge protection devices also provide protection from HI/LO voltage conditions as well as issues with the neutral and ground (ie: reverse polarity and open neutral). These are the most common problems that you will encounter with a campground power source and are conditions that will destroy electrical components pretty rapidly. I have experienced power issues several times in the 11 years we have been RVing (the campgrounds in the northeast are pretty dated) so I believe they are worth every penny.
Lou
05 Travel Supreme Envoy
Shadow_Catcher
Living in Ohio and having a certain number of thunderstorms and our home has three layers of protection for surges. We have had neighbors who have lost expensive electronics.
Camping trips where there have been thunderstorms I pull the plug from the pedestal, but what happens when we are out and about and a storm comes up.
This is apart from faulty pedestal wiring, open neutral... I have observed burned plugs in pedestals.
Our progressive Industries will not connect if the wiring in the pedestal is not functioning correctly, lets me monitor voltage amps and frequency.
CA_Traveler
"Surge" means virtually anything including as you suggested "spikes". In 2004 I looked at about $3,000 of electronics and for the first time bought a "power protector" also know as a EMS unit. It protects against "spikes", high/low voltage, reverse polarity etc.
So I installed a PI HW50C and have been protected against numerous CG faults. In my current rig the HW50C was free as in $0 - Yup I moved it from the last rig.
Unlike your house CG power especially at the pedestal is often worn and abused. And the entire distribution system may be suspect - Yup I had one occurrence of 160V on a 30A pedestal.
It's like insurance - your choice.
2014 Grand Cherokee Overland
Bob
rk911
the park we're currently in strongly recommends the use of a surge protector. and on the same posted notice offers to sell one to those who might want one. in 30-years we've had only one electrical issue that I can recall and that was solved by moving to another site. yet when it came time to trade-in our 2000 model yr MH for a 2016 model one of the upgrades I wanted was a progressive surge protector. I doubt we'll ever need it but then I doubt our home will ever burn down and I would not be without my homeowner's insurance.
we went with the hardwired unit and mounted the remote monitor panel inside the coach. I wanted the hardwired unit so I didn't have to mess around padlocking it to the electrical post. as my grandpa would say...if you don't want it to walk away put a lock on it.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
TucsonJim
DutchmenSport wrote:
A RV surge protector is kind of like wearing underwear. Do you REALLY NEED underwear? Actually ... no. No one can see what's "under" your top layer of clothing anyway. BUT.... It sure does feel more comfortable.
Same with a Surge Protector. Do you REALLY need it? well, probably not. But to have that "comfort feeling" you have a little better protection than nothing at all ... well... that's your choice.
Boxers or shorts?
Clearest explanation in the history of the internet! You win.
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
DutchmenSport
Boxers or shorts?
