mtnsun99's avatar
mtnsun99
tag axle
I just bought a 94 newmar motorhome with a tag axle..I don't know how it works or when to use it. Can anyone help me? Thanks
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to "posting" issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
  • Tyler0215 wrote:
    Iy works all the time, just like a regular axel, only it is not powered. It increases the load capacity and has a set of brakes. Brakes and bearings are the only service needed.
    and tires
  • You also may have a switch for the tag dump, which is used during sharp turns.
  • Iy works all the time, just like a regular axel, only it is not powered. It increases the load capacity and has a set of brakes. Brakes and bearings are the only service needed.
