prstlk wrote:
Some previous threads have talked about a solenoid bypass. My question is, can I just do the bypass at the switch?
jw
NO, you can not.. THOUGH if it is the SWITCH and not the SOLENOID there may be a very, and I mean VERY!!!!! easy fix.. I will describe it
Kill power to the switch Eithr pull the proper fuse or disconnect all batteries (both sides) and then....
Cycle the switch 50-100 times
Restore power and see if it works
But bypassing the switch will do no good as it is the SOLENOID that is the "Real Switch" that button you push is a remote.
