Nov-09-2018 01:40 PM
Dec-03-2018 12:04 PM
camperdave wrote:Jq1953 wrote:
Thanks for the advice about the running lights. I am sure these were resealed with the seams. Winnebago did offer to look at my coach, a couple of years ago, if I returned it to the factory, but that's not feasible due to medical concerns of a family member. It ironic that we purchased a Winnie based on recommendations of several campers we asked. I guess I just drew the short straw this time.
Find a local outfit with a whole RV pressure type leak tester. Unfortunately, after a few years of water in there, I'd be worried about rot, even when the leak is found and sealed.
Dec-03-2018 09:49 AM
Dec-03-2018 09:05 AM
Jq1953 wrote:I praise our rig the Phoenix Cruiser, but as you experiences with Winnebago, a bad apple surfaces now and then. It is unfortunate for you, left dealing with a problem with no resolution. I wonder if the "Lemon Law" might apply in your case, but it has been 5 years since you bought your rig new.
It is ironic that we purchased a Winnie based on recommendations of several campers we asked. I guess I just drew the short straw this time.
Dec-03-2018 07:36 AM
Dec-02-2018 07:56 PM
Jq1953 wrote:
I purchased a 2014 Minnie Winnie in June 2013. I have had several issues, some normal, some not normal. I spent the first year talking to Winnebago and taking it to two different Camping World dealers. My problems still existed after these visits. I got only promises from the factory and the dealers.
When the warranty expired I took it a local dealer and paid for several repairs. But I have never resolved a rook leak over the drivers side.
In June of 2018 I took my coach to Camping World in Garner, NC. I spent 2300.00 to have the seams removed and resealed. Still a leak. After two returns I have decided to return it again. I after this visit I'm going to trade. But not for another Winnebago. I don't know what's better. I will just roll the dice again.
Dec-02-2018 05:36 PM
Jq1953 wrote:That very persistent water leak would be a very tough pill to swallow. Shame on Winnebago not resolving it for you, and very unfortunately nobody else either.
Dec-02-2018 03:50 PM
Dec-02-2018 03:25 PM
Nov-29-2018 09:31 AM
ron.dittmer wrote:camperdave wrote:I know what you mean. But for me it was all about the over-all height of the rig including the a/c unit. Our rig clears our 9'-11.25" tall garage door opening by 1.5". Our house floor is only 1.5" higher than our Ford cab floor, and our interior ceiling height is less than most other makers. I think the company Phoenix USA had originally marketed their products many years ago as a big class "B". They are officially class "Cs" but scaled down significantly compared to most others.
I ruled out Jayco and Bigfoot because they all have basement storage. Which is nice in some ways, but it raises the house relative to the drivers cabin which I do not care for. I didn't like that you couldn't see out the front window from the couch or dinette.
Nov-28-2018 10:12 PM
Nov-28-2018 12:30 PM
Nov-28-2018 12:03 PM
BFL13 wrote:Please correct me if I am wrong, but I believe there are 3 Ford-standard wheel bases, 138", 158", and 176". The 176" is rarely used in the shorter lengths. Keep in-mind that some RV outfitters adjust the wheel base to fit their particular floor plans. There are Ford & Chevy approved shops doing it for a living. It sounds like a science project given all the specialty parts required, but I believe everything is available from Ford & Chevy in particular increments.ron.dittmer wrote:I don't know much about other Class Cs or Fords, but am curious about the above figures.
I agree in that 25 feet is a good cut-off between a Ford E350 and an E450 chassis, a Chevy 3500 and a 4500.
An E350 chassis at 24-11" would be fine as long as the frame was stretched increasing the 158" wheel base to notably more. This would better distribute the weight between front and rear axles, properly utilizing the extra load capability of the front axle.
Most short rigs have too much weight on the rear axle, and too little weight on the front axle causing "rear end sag". The condition also negatively affects handling. Our 11 year old E350 rig is 23'-8" long with a Ford standard 158" wheel base suffers from it. I had to invest in suspension upgrades to get the handling just right. Our rear end sag is very slight, a non-issue.
The 1991 E350 dually we got last year (see pic in profile) has a wheel base of 176 inches and has 140 inch overhang behind that, the way I measured it. (front to rear axles) That is 26.3 feet and brochure says the Rv is 28.5 overall, so add a couple feet from front axle to front bumper as well.
I have no clue where that 158" comes from. Is our E350 something special? Or is that for newer ones? I can say our rear axle is maxed even before we load anything, and it came with air bags OEM. The RV maker put more "house" on there than the "incomplete truck" was supposed to carry it seems. Still on the road though! 🙂
Nov-28-2018 11:57 AM
Nov-28-2018 09:41 AM
