dougrainer
Apr 15, 2021Nomad
ThruTraffic wrote:dougrainer wrote:
Your tstat and Communication cables and roof top controls are specific to Dometic. If you go to another Brand, you will have to run new Tstat Cables from the wall to the roof and change out the wall tstat and the upper control boards, which adds cost.
Not exactly true. the Penguin II and CCC2 for example use a 4 conductor RJ11 (phone) connector. They don't even supply this cable you have to make one and run it UNLESS your old system has a cable already run with at least four spare conductors. If you have the spare conductors just buy some RJ11-6p4c connectors and attach your old wiring to them. The Penguin installs doc has the wiring pin-out for you to do just this. Odds are you won't have to run wire in a change out; new install, yes.
What I posted is TRUE. The 4 wire com cable IS SPECIFIC to Dometic systems that use the Com Cable. What did I post wrong? Doug
38,709 PostsLatest Activity: Mar 09, 2025
