j-d
Apr 29, 2016Explorer II
I had to notch just a little. Eight-Round-Hole Simulators, BORG Dually Valves. Easy enough. But I'd suggest you cut or grind your notches. I did that on one side after I thought I could dimple the stainless steel a little to gain the clearance and it cracked. I'd rather have a ground-out spot (Dremel Tool) than a crack. Still, the tiny crack has not spread.
38,707 PostsLatest Activity: Feb 18, 2025
