mdecastra's avatar
mdecastra
Tire Pressure
I bought used, from dealer, a 2014 Fleetwood Southwind 32VS. Just weighed it as follows: Full Gas Tank, 2/3 Full Fresh Water, 1/3 ea on Grey and Black, Fully packed incl DW. Front axle weight is 6,880 lbs...Read axle weight is 19,480 lbs. Tires=Michelin R235/80 XRV @ Max single 4675 dual 4410.
1) Are my tires rated to handle my unit?
2) What PSI should I run, per axle?
It appears my front is under weight and rear is over weight. Can I run rear ties lower PSI that rear.
I also have a TPMS 507RV/SG which I can program different tires for different pressure and temp.
