DSDP Don wrote:
Canadian Rainbirds wrote:
That has not been true for radial tires for decades. It was a concern in the early days.
You're absolutely right that it doesn't apply anymore to PASSENGER CAR tires, but you'll most likely cause tread separation on large RV tires, especially models like the Goodyear G670. I never change direction on any tire, personal preference, but I would never change direction on a large RV tire and take the chance that the tread separates and causes a blow out. Your RV, your choice.....change tread direction if you like!
I would think RV tires would be the same as truck tires??? On my Peterbilt, I rotate the fronts from side to side once in their 250,000 mile life. I also rotate the rear tandems. On them I swap the RF to LR, the LF to the RR. I leave the outside tires on the outside, because the wheels are polished on one side, and I do not have to remove tires from the wheels this way.
This is the method, told to me by several truck tire shops, that is reccommended. This changes direction of rotation of all the tires. Never had a problem, and it is the suggested rotation method by truck tire shops.
