BigLar368 wrote:
Thanks for all the advice. We are going back in a week or so and drive it again. I feel the tire probably just has a flat spot. It has been on their lot since August. The salesman said no one has even tried to make an offer on it. With diesel being as inexpensive as it is now seems like everyone is going for the longer MH's.
BigLar368,
Well Sir, first off, why would only ONE tire have a flat spot? I mean if all the tires are dated close to the same, as in they've all been on the coach for the same amount of time, and the coach has been sitting for a while, then if the coach tire(s) were to develop a flat spot on one, it would do it to all of them.
You could do a very simple test here without to much technology involved. I'd put that coach on some flat ground and, lower the Jacks 'till they hit the ground. Then, raise the front end, 'till the front tires are just BARELY off the ground. All you need is daylight under the one in question.
OF course the parking brake is set already (you can't lower the jacks if it isn't)so, the coach is not going anywhere. Now, what's needed next is an object, a coffee can, block of wood, anything that will sit sure-footed on the ground that's not very high. All you have to do is put that object very, very close the tire tread. Then, spin the tire slowly.
What you're looking for with this very simple test is this. If the tire is "Out of Round", as it spins, it will move considerably closer to the object you've placed in front of it. You'll see the clearance decrease and increase, between the tread and the object if the that particular tire is out of round. This test, putting the jacks down and raising the coach to the point the tire's off the ground, will take about 3-4 minutes.
Then you'll know for sure if you're dealing with an out-of-round tire. You of course can do the test to the left front too, while the coach is up off the ground a bit.
Now, that test primarily reveals out-of-roundness. It will not show "out of balance" issues. Now, I've not heard of it on Motor home tires like I have on trailer and regular vehicle tires but, you might possibly find a tread separating too which, would show up a bulge in the tread face at one portion of the tire. Again, never really heard of it on a motor home tire.
But, if you like the coach, and all else is well, then a balance problem or vibration shouldn't cause you to back off of the deal. Nothing is that hard fix, especially a vibration. A good tire shop or truck front end shop should have that problem diagnosed in minutes.
And, as far as "Salespeople" actually "KNOWING" about what they're selling, well, you've more than likely seen that before. In all reality, not very many sales people are truly knowledgeable about their products. Many will "talk" like they know a lot but, I've put many of them back in their chairs. There are a few, VERY FEW, that really know their stuff and can accurately answer questions, describe what a coach is and how it works and things like that, but not very many. Good luck on your endeavor.
Scott
