hohenwald48 wrote:
Over the past few weeks I've been shopping for a low miles (25k or less) used 2007/08 motorhome. No particular brand. I've gone to look at several and probably called 10 or so for additional information. With the exception 1, all have had the original tires. Come on folks 10 years is a little long in the tooth for RV tires. No wonder you hear so many blow out stories.
If you look even further back you will still find even more original tires - the stories of blow outs are usually because as the coach gets older the owners tend to not keep an eye on the pressure in the tires (generally the issue for a blow out, just no one will admit that THEY are the problem) - IMHO buy what you like and then find your replacement tires - drive it in and change them out, in most cases you will not find a Coach with less than 25K miles on it that has new tires, just not going to happen.
JMHO,
