aboeck3
Sep 05, 2014Explorer
toads
2 questions: I have been counting toad vehicles today on a trip from Kansas City to Sikeston, MO. the majority of 4-down toads are Jeeps, why is that? 2ns Q, what are the pros and cons of towing with a dolly?
RFCN2 wrote:
The reason there are so many Jeeps towed behind motorhomes is because they are extremely easy to hook up and remove. There are no limitations on towing as far as speed and distance. No fooling around with starting the car up and running through the gears before towing.
I have a 2013 Jeep Wrangler 4 door I bought new. Why is it easy to hook up and remove.
1. The Jeep Wrangler is a great height for 66 year old backs to hook up. We had a Saturn LS300 before the Jeep. I like the height of the Jeep much better.
2. When you get your tow bar hooked up to make the Jeep ready to tow you pull the transfer case into neutral. Move transmission into park and pull out the key. Thats it. 20 seconds. When you unhook it is the reverse. Also 20 seconds.
3. No fiddling around with running your car and shifting the transmission to oil it up.
I have had my Jeep for 18 months. I have driven it 18,000 miles and towed it another 12,000. It has needed exactly zero fixes except I broke it at Moab last April. But Jeep made a very good vehicle.
The newer Wranglers ride better and are quieter. I went in to buy a Jeep Grand Cherokee and ended up with a Wrangler. I told the sales guy I could not live with the rough ride of a Wrangler and the noise. Guess what, they now ride smoother and are not so noisy. That said it does not drive nearly as smooth on the freeway or as quiet as my wife's Acura MDX.
The other car we were interested in was the Acura that is the same as the CRV. My biggest objection to the Honda CRV is that it is too slow with it's little motor. And the handling compared to an Acura is poor. Mushy and sloppy around corners. Our Acura MDX is like a sports car SUV with good handling. The Honda is not a sports car. But Honda in their wisdom put a six cylinder motor in the small Acura SUV and then stupidly made it so you could not tow. Same for MDX. Our old MDX (2003) was towable.
The Jeep has a six cylinder and far livelier acceleration than the Honda CRV. Plus the Jeep has tight suspension and it feels good going around corners. So for me I liked the Jeep for a tow car. But that is just my preferences. Many of my close friends tow CRV's. I have owned 2 Accords and 1 S2000 Honda. Great cars.
Jeeps also have a low range that Hondas don't. This means you can get yourself in places with a Wrangler that no Honda CRV will go. If you come to a huge steep hill you have to have low range. No low range and you will spend a lot of time waiting for your torque converter to cool.
There is no Honda CRV week at Moab. Enough reason alone to get the Jeep.
Trackrig wrote:afrescop wrote:
We have many horror stories from the few Chrysler products we owned in the past so that company is a no-no.
Please don't call a Jeep a Chrysler product - I might be forced to sell mine. It's a 2002.
Bill
Tom/Barb wrote:
we simply are aware of the problem, and make our turns a little wider and smoother. It only happens in sharp turns.
OBTW our hitch is 11.5 feet behind the rear axel. the jeep is 5 feet behind that.
Mr.Mark wrote:Glad to hear the good info Mark on your CRV, we just bought a 2014 but I haven't towed it yet!Tom/Barb wrote:2gypsies wrote:Mr.Mark wrote:
Tom, I think I would get a new tow bar. That can't be good for the Jeep front-end or the tires.
MM.
X2. I think the problem is with your tow bar. Our Blue Ox & Jeep poses no problems.
The Blue Ox works on the same principal as the Falcon, they both extend and lock.
Our coach has a tag axle but the pivot point is the drive axle. I've never measured the distance but it has to be about the same as yours. Our tow bar from the hitch to the front of the Honda is probably 3.5-4.0 ft.
I have raised the tag many times to make that sharp turn. I'm telling you that I've been amazed at how sharp I can turn our coach. Thank goodness the steering tires are behind the driver's seat as I can hang the front of the coach over a curb and make the tightest turns. The Honda steers normally.
Safe travels,
MM.
MM.
MM.
MM.
