oldtrucker63
May 06, 2010Explorer
lzasitko wrote:Can't run conduit through the wall because of the steel framing that is also in the walls, And if I run the wires inside the walls it must go up to the roof to cross the steel rails and them back down into the walls and from frount to rear thats 4 times, Thats the way the factory had it run I will have to stay floor level with most of the wiring, Only the cab marker lights will have two wires up top and a few 120 volt wires.
Or you could also put in the walls rigid conduit. Comes in either metal or plastic but it would allow you to add more wires if needed or remove and replace. Just use a fish tape to go through it. Then it is not exposed to the elements and easy to change.
38,705 PostsLatest Activity: Jan 24, 2025
