john_b1
May 11, 2010Explorer
I admire your progress and ingenuity on your project as it is starting to come together. A 2 cents contribution if allowed.I have soldered wiring in all phazes of rv & general automotive wiring and it is very reliable & cost effective when done correctly with the proper products.I have even in the right circumstances soldered and then shot the appropriate size wire nut full of silicone and installed it for a tight weather resistant connection with integrity When you see the scotch connectors etc they have used for years in RV manufacturing with a very high failure rate makes soldering look ike a well planned savior for reliabilty & longivity.
Also any thing you use with sticky tape on it usually doesn't stand up to the heat in an Rv so to use those types of wire hangars seems to be it could be another weak link. We have witnessed many so applied devices fall down in mid summer,I sure wouldn't want that to happen inside a wall or something. Just my 2 cents & keep up the good work.IMHO
38,705 PostsLatest Activity: Jan 22, 2025
