โDec-10-2009 06:16 PM
โAug-23-2011 12:02 PM
โAug-23-2011 11:59 AM
โAug-23-2011 11:58 AM
skimask wrote:10/4 Thanks I will check and find out just what I will need, I would like to have it like the house thermostat or say like the one for the furnace that is on the wall.oldtrucker63 wrote:
Do they make a wall thermostat that will handle that voltage.??? I will check it with my meter to see what kind of Voltage/amps go through it.
The thermostat wiring will be the full ~120VAC/high-current. But I was thinking more in terms of mounting one of the thermostats like the one in your A/C in a box and mounting THAT on the wall. It won't be calibrated just like it isn't cal'd now (i.e. won't be marked in degrees and such), but it should work.
If you're thinking more along the lines of like what your house has, that'll take a bit more work (i.e. standard thermostat, 24v power supply, a relay, etc.etc.etc) but I think it could be done without much problem. Just gotta round up the pieces/parts.
โAug-23-2011 08:36 AM
โAug-23-2011 07:16 AM
โAug-23-2011 07:15 AM
โAug-23-2011 06:00 AM
tboss wrote:
driver if there is a diff. in the wire size pls be careful.. they are two diff. beast.
one carries 110v and the other carries milivolts..one starts a fan motor and compreser and the other simply sets a relay...
โAug-23-2011 05:12 AM
โAug-23-2011 04:51 AM
โAug-22-2011 10:28 PM
โAug-22-2011 09:12 PM
skimask wrote:I would think it would fail, I'm now looking for a replacement for this, And I had in mind of trying to run a wire to a wall mounted thermostat, I think this will work.??:h
That's what I was thinking it was. It's a relatively common, standard, thermostat for A/C units.
dime-to-a-dollar says if you find an old broken house A/C unit laying around somewhere, or any other A/C unit for that matter, you'll find a switch just like it.
I'm thinking in terms that if the wire got hot enough to melt itself off, I'm wondering what kind of damage it may have done to the actual temperature sensing element inside the thermostat and whether or not it'll fail in the future.
โAug-22-2011 08:03 PM
โAug-22-2011 06:11 PM
โAug-22-2011 02:45 PM
โAug-22-2011 02:39 PM
