Put 'em on my Class A, along with a set of Dually Valves on the rear, when the time came for new rubber... Over a thousand dollars less expensive than Michelins with FMCA discount (I checked)
Only complaint was against the installer. NOT the tire (They did not replace front valve stems. only the rear. had one of the front valve stems break. This is not a tire problem but it would have been under different conditions)
The biggest difference in those tires is tread life.. They won't go as many miles (If installed on a semi truck)
On an RV you won't wear them out .. you will age them out (Same as the Big M tires they last about the same number of years)..
No complaints and saved big bucks. Only poked one hole in the tire company parking lot (They really needed lessons on jacking up a motor home at the store)
