mygsds's avatar
mygsds
Tow dolly question with Vibe
We are using our tow dolly for thenfirst time this weekend with our Vibe. I figured I had to leave in neutral and larking brake off but key cant come put if set that way.
What is requirment for setting car for towing like this?
Pat
  • The Acme does not have a pivoting platform. You need to unlock the steering column as previously posted Wildebill308.
  • mygsds wrote:
    Thanks we bought used an Acme and watched the video but it didnt specify.
    You should go to the Acme website and down load the owners manual.
    http://cartowdolly.com/online-owners-manual/
    From the owners manual,
    Emergency brake must always be released. Front wheel drive cars can be towed in park. Consult owner’s manual about towing Four Wheel Drive or All Wheel Drive vehicles. If your car uses a locking steering column, we recommend that you leave you keys in the accessory position to allow your wheels to turn freely.
    Bill
  • Thanks we bought used an Acme and watched the video but it didnt specify.
  • Front wheel drive, should be in park or gear, parking brake off.
    Which tow dolly?
    Information from Demco website and in manual.
    Step 7. Drive vehicle onto the platform - front forward - until
    tires touch the wheel stops at the front of each side of the
    platform and the platform tilts to a flat position. Make sure the
    car is centered on the platform. Towed vehicle tires must fit
    in wheel troughs without overhanging sides. Engage towed
    vehicle parking brake. Shift loaded car into “park” and lock
    steering wheel with front tires in a straight position. If the car
    does not have a locking steering column the steering wheel
    must be tied securely with front tires in a straight position.
