Dec-12-2017 01:45 PM
Jan-04-2018 09:49 PM
Passin Thru wrote:
Uhaul uses them because they are cheap. I am a professional driver. Drove Tractor Trailer and then pulled boats TTs and enclosed trailers and I don't like them. One has O control over how much they apply. In an emergency on wet or snowy pavement, you are simply in for the ride!. So you like them. So what? go ahead a buy them.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Jan-04-2018 09:45 PM
Tom/Barb wrote:Passin Thru wrote:
Surge brake are to cause accidents IMHO. I don't like them. Rent a trailer with brakes and drive it like you own it. You probably have the brake setup anyway.
Guess they cause so many accidents is why U-haul uses them on almost every thing they rent.
Jan-04-2018 08:06 AM
Jan-04-2018 04:35 AM
Jan-03-2018 06:05 PM
Georgia Popcorn wrote:
I tow a 2017 SPORTAGE with an ACME TOW DOLLY, with surge brakes, what's your feeling about traveling in NEUTRAL v/s IN PARK with steering wheel in UNLOCKED position, key in ignition?
Jan-03-2018 05:51 AM
Grandpa Tumbleweed wrote:
we had a tow dolly without brakes and I felt that there was no problem on several 3k-5k trips, I replaced it with one with surge brakes and found that there was a big difference, although they were not panic stops the motor home did stop better I will never tow without surge brakes. Florida requires brakes on towed units over 3000 lbs
Jan-02-2018 01:10 PM
Jan-02-2018 09:07 AM
Jan-02-2018 07:26 AM
Dec-27-2017 08:44 AM
Dec-26-2017 09:40 PM
Larrysr1957 wrote:
I will be renting a uhaul tow dolly for a trip I will be taking I am pulling it with a 1998 35 ft. Bounder the vehicle being towed is a Lincoln MKX I will be traveling at approximately 60 mph 400 miles each way does anyone see any problems with this setup
Dec-26-2017 06:15 PM
Dec-24-2017 08:33 AM
Dec-24-2017 05:24 AM
