lostdog wrote:
booty51 wrote:
OK to clear some questions up its an 06 Wrangler, key was set in first click position to allow steering wheel to turn per towing proceedure, rough roads and maybe sweeping turns in tight areas is where I have experienced lock up.Will look into removing steering wheel lock.
Do you have a lot of heavy "stuff" hanging of the key ring? General Motors is going thru this right now. If you have a lot of keys on the key ring it can get to swinging while going down the road and turn the key to the lock position. Just a thought.
That was my first thought when I read the OP. Actually, this is nothing new, it has been a slight problem since they took the ignition switch out of the dash board and put it in the steering column! I remember reading about it years ago. The recommendation back then, as now, is to NOT have a big mass of keys (and other stuff) on your key ring.
The best bet is to have just the ignition key in the switch, with nothing hanging on it.
I, too, have never had this problem with my '06 Wrangler.
