โOct-25-2017 06:48 PM
โOct-27-2017 07:24 PM
ArchHoagland wrote:
Have you ever weighed your van and trailer fully loaded with everyone in the van, water, fuel and waste water in the trailer?
I would really be curious whet the total weight is.
โOct-27-2017 06:02 PM
โOct-27-2017 10:43 AM
gutfelt wrote:Jesshopes wrote:gutfelt wrote:Mfan wrote:
I see full size pickups behind prevosts, they don't seem to have a problem
yes but where do u put 11 kids? and he says there on a tight budget
My opinion a decent older used prevost is still 150K or more
And FWIW...I'm a she...
well you said "we" so I had a 50% chance of getting it right LOL
โOct-26-2017 12:05 PM
โOct-26-2017 10:14 AM
โOct-26-2017 09:22 AM
Jayco-noslide wrote:
Just as if you were towing anything behind anything, check the manual to see how much it is rated to tow not forgetting what will be in the towed vehicle. And of course, each pound of weight uses more fuel and energy to move. Man, you are brave. I can't imagine going much of anywhere with that big of a family. The weight of your family must be over a ton.
โOct-26-2017 08:01 AM
โOct-26-2017 08:00 AM
โOct-26-2017 07:30 AM
โOct-26-2017 06:07 AM
โOct-26-2017 05:25 AM
Jesshopes wrote:MrWizard wrote:
with 11 children plus adults, you may be looking at band buses ?
to sleep everybody, it depends on age, and how many to a bed
many a band bus has been used to pull a trailer full of sound equipment
and good box tt are not light weight
a band bus, should have the total GWC needed
We've definitely looked at the bus option. There are two things I don't like about them. 1)They often don't have a complete kitchen and 2)They have no slides. 13 people in a RV means I really really want the extra room a slide produces. There are definitely some MAJOR pros to them, though
โOct-26-2017 05:20 AM
Ivylog wrote:
Do both of the "WE" drive the van? Assuming you are not doing a several months trips have one driver drive the van with some of the children and the other the MH with some of the children. What you are trying to do cannot be done on a small budget.
We currently tow a 37 ft TT behind our 15 passenger van. We've started toying with the idea of getting a motorhome. We have 11 kids so a smaller vehicle isn't an option. All of the GVWR numbers make my head spin a bit. Does anyone tow a large/heavy vehicle like mine behind their MH? We've found a couple of gas MH's that have 5000lb hitches on them. Is there a gas MH out there that would have the power to tow more than that? Are we crazy? (We are on a pretty tight budget and are looking for used MHs)
TIA
heres the perfect set up and very well priced http://horizoncoach.com/index.cfm?go=main.inventoryView&inventory=2063
โOct-26-2017 05:19 AM
โOct-26-2017 05:18 AM
TIA
you will need a MH with a 10K tow capacity hitch and theres not a gasser alive that will have a HD hitch and the power or the GVCC
that will do the job:: Also theres no MH,s out there that will work for 11 kids
