Geeze's avatar
Geeze
TPMS
I'm considering adding a tire pressure monitoring system to our Class C mainly so I can monitor tire pressures on our toad. What system do you use if any and which type of sensor works best on the inside duals, flow through or the more compact theft resistant? One manufacturer did not recommend installing the flow through on the toad due to the added length. Thanks
About Motorhome Group
38,707 PostsLatest Activity: Feb 28, 2025
