rooster wrote:
Thanks for the reply, but the problem is the door is "raked" at the top, to match the rake of the windshield, so their are NO hinges above about the center of the door.
OK, I can see where that would present a unique problem. Going forward, since the fit is terrible at the top to start with. If it were my RV/door, I'd block the center horizontal part of the door with a 2x4 or such and carefully, add pressure to the top of the door to BEND the door enough to properly seal at the top as compared to the bottom.
I know this is a gutsy suggestion and if your tentative to attempt it, I'd suggest finding a body shop repairman and get his input as to getting the door back into shape.
