BoatCop's avatar
BoatCop
Ventilated Generator Compartment Door.
Are generator compartments designed for maximum cooling (ventilation) with solid doors? Or would replacing the door with a louvered or expanded metal door aid in cooling.
I usually run in the desert and southwest, where temps can be 110* - 120*. I was thinking that better air flow via a ventilated door would help the generator run cooler.
