- mlts22Explorer III have seen Sportsmobile mount taller generators. One of the issues is angle of departure, and last time I was under a "B", the generator was well out of that angle. From the video, it looks like the generator under the Travato is well under that angle as well, and protected by skid plates.
So far, I've not read anything about smashed generators, so I'm going to assume that for most things except for some of the nastiest terrain, the engineering is good enough to not worry.
The 2016 model has some incremental improvements. It has two AGM batteries, and the 59G goes with the Truma water heater and furnace. One can wait forever, but in life, one isn't getting any younger, and better get out camping while you can. - S_K_Explorer
wincrasher65 wrote:
If you wait until something better or improved comes out, you'll always be waiting and never buy.
There is constant improvement in all models, as most manufacturers make running changes throughout the model year.
The only thing I know for sure is that there are some additional color choices available for 2016. The 59K is slowly being rolled out and there most likely will be tweaks to this model as time goes on.
Just sent you a PM. - wincrasher65ExplorerIf you wait until something better or improved comes out, you'll always be waiting and never buy.
The only thing I know for sure is that there are some additional color choices available for 2016. The 59K is slowly being rolled out and there most likely will be tweaks to this model as time goes on. - S_K_Explorer
wincrasher65 wrote:
I believe now if you order a new van from the factory it will be a 2016 model. Someone said there are additional colors, but haven't said there were any new features.
Top of my list for things I'd like to see is the Truma system and a second battery. Think both of those are do-able.
Any update on any pending changes on the 2016 model yet? I understand that the 2016 59G model is already on the market but I guess it is an early version of the 2016 model at this time, most of the features are probably still similar to those of the 2015 one. I am seriously considering downsizing from my current TT/TV combo to a class B and the Travato 59G is one of my top choices. Any reason you would advise me to hold off a bit and see if any significant updates such as the Truma system will be implemented? Thanks! - stan909ExplorerLots of Sportsmobile off road vans with AGM batteries underneath with little to no issues.
- bobojay5Explorer
Davydd wrote:
Do AGM battery terminals have issues with corrosion that need tending and terminal cleaning or tightening? I never once saw the AGM chassis battery in my 2010 Sprinter in four years of ownership.
No they don't. There's no spillable liquid in them. Their outgassing is recycled back to the plates, (simple explanation) - SkiMoreExplorer IIThanks. A lot of great information in that video.
- avantiExplorer
I've never seen a hint of corrosion with AGM. - DavyddExplorerDo AGM battery terminals have issues with corrosion that need tending and terminal cleaning or tightening? I never once saw the AGM chassis battery in my 2010 Sprinter in four years of ownership.
- bobojay5Explorer
jrobe wrote:
I would also be concerned about having my batteries exposed to the elements under the van. How does this work in rain, snow and mud? One rainy day on a dirt road and you would have a mess in those exposed battery slots.
This seems like a van built for blacktop roads which is fine for people that never leave the main highways. There are a lot of interesting places though that this van wouldn't see. I love the floor plan though.
Exposed battery slots? What's that? These are AGM batteries that WGO installs. They are sealed top, not serviceable. Only thing sticking out of them is the small posts with the bolt holes for the cables.
On the WGO Sprinter class B's, the coach batteries are right behind the rear wheels on both sides. Granted Sprinters have splash guards on the rears, but there is still a lot of water spray gets back there. Never been an issue for us or anyone else, (5 of them), that we know with the same setup.
Like has been said, 6 1/2 or 7" clearance back there is higher than most cars out there
About Motorhome Group
38,763 PostsLatest Activity: Dec 13, 2025
