pchuckie's avatar
pchuckie
Vista LX 35F
I see the Vista LX 35F has separate black tanks for the two bathrooms. Does anyone know if it has two seperate sewer hookups?
My current 5er has two seperate grey tank hookups, what a PITA. Two seperate black tank hookups would be less of a hassle. I seen a RV at the Hershey show thay had two seperate black tanks and it had a switch for the front or rear blank tank. I don't remember the brand or model.
  • I have a Itasca Sunstar 35f and its rock solid. Check out the shower, its BIG. haven't used one in a camp ground yet. The two black tanks is no problem with one hook up. You won't go wrong with a Winnebago product.
  • Thanks for th reply. Camping world near me has one and I didn't realize it. Your right it is a pretty simple setup.
    Do you own one? It's very similar to the Bounder 35k. The Bounder was our first choice, after seeing the Winnebago it's close to a tie. One nod goes to the Bounder because the Winnebago's cab over bunk is a twin bed, while the Bounder cab over bed is a queen.
    I noticed some condensation inside the storage compartment just in front of the rear wheel on the drivers side.
  • The 35F has one outlet for both of the black tanks and the gray tank. Each of those three tanks has its own dump valve but only one discharge hose is required for all three. Easy to dump.
