philnk's avatar
philnk
Warning buzzer
I'm trying to re-install the warning buzzer in my 1995 MH with Spartan chassis. I can't figure out the wiring. There are several white wire pigtails and a red one, violet one, black one, gray one, and orange one. Could someone clue me in on what goes to the colored wires?
It seems to me that the only colored wires coming from the buzzer are for ground and hot wires.
  • Critical systems buzzer. Low oil pressure, high temps, brake warning, etc. what goes to the idiot lights.
  • I contacted Spartan for a few things and they sent me wiring schematics for my Spartan Chassis............Make sure you give them the VIN and I believe they will help provide you with a wiring schematic. Please let us all know how you made out.
  • I called Spartan and the guy I talked with couldn't find anything for my 1995 but found the wiring for a 1997 which showed only blacks, grays and a white lead. That didn't help. I'll call again to see if someone else answers with better results.
    Dang.
    I struck out about 10 times trying to find out info on my 1995 Gulfstream. It must be the worst ever for documentation.
  • if it has a idiot light, you can wire it positive to positive of the light, negative to negative of the light, the light comes on the buzzer comes on. piezo usually doesn't draw much amps.
