โFeb-16-2015 02:41 PM
โFeb-22-2015 04:11 AM
holstein13 wrote:Brian in Michigan wrote:Interesting. Did you try doing a load of bleach? Mine has a bleach setting that does nothing but clean the washer and drain.
No, the drain hose, I, and a few other people I know have had this problem. The slime will build up in the discharge hose and will create quite a nasty smell when the next drain cycle starts.
โFeb-21-2015 12:04 PM
โFeb-21-2015 11:37 AM
โFeb-21-2015 10:28 AM
holstein13 wrote:Brian in Michigan wrote:You mean the detergent dispensing hose, don't you? The one that goes from the detergent receptacle to the washing drum? I can see how that might happen.
One other addition to the front loaders. If to much soap is used it can build up bacteria in the discharge hose and can smell like a septic tank. Put in only what you need to get the job done. ( Past experience )
โFeb-19-2015 02:41 PM
โFeb-18-2015 12:58 PM
โFeb-17-2015 01:56 PM
donn0128 wrote:Oops, yes, you are correct. We actually have the stacked washer and dryer in our coach that is bigger than the Splendide. It's probably not a good idea to use these in the smaller washer. I read the instructions and these are about right for the loads we do.
Those things are designed for standard size wash loads. They are about double what you should be using
โFeb-17-2015 07:29 AM
โFeb-17-2015 03:33 AM
dad2aprincess wrote:
What kind of washing detergent do you guys use, and where do you buy it? We have a Splendide washer/dryer combo, and my wife insists we need to use their detergent, which is quite pricey once you have it shipped. Is there a good reason to use the Splendide brand, and if so, have you ever found it in a store?
โFeb-17-2015 03:17 AM
edatlanta wrote:
Tide HE here, but no scent. I can't stand all of the fake smells. Just clean is good for me.
โFeb-17-2015 02:08 AM
โFeb-16-2015 06:16 PM
โFeb-16-2015 05:54 PM
โFeb-16-2015 04:30 PM
sch911 wrote:dan-nickie wrote:
Can someone tell me what the HE stand for?
High Efficiency - Most new home units, especially front loaders are HE. They use very little soap.
