wa8yxm
Jul 28, 2013Explorer III
Most filters restrict water flow something fierce.
One solution is to use TWO regulators.. Both Watts whole house and clearly labeled (paint one)
one is put between the filter and the RV set it at 45-50 PSI
The other is set between the park and the hose to the filter (Which by the way needs to be as close to the RV as it can get, OUT of the sun if posible) and set that one to like 60-75 PSI. You hose should be able to stand 80.
38,705 PostsLatest Activity: Jan 20, 2025
