SKIPCAROLExplorerJul 28, 2013water filter and pressure regulaterWe are at a campground with high water pressure and use a regulator (we always do)and a filter. By the time it gets to the tap, pressure is really low...if I take the filter off it's ok. Do you think...Show More
joeprinterExplorerJul 29, 2013Is the pressure just as bad with water pump only. Mine did this, an A Change of filter did the trick.
Related Contentoil filter?Front grill filtertire pressureWater Pressure RegulatorRam 6.7 fuel filters
