billyboy's avatar
billyboy
Water filters
Does anyone have the under counter filter made by 3M and know where to buy it. It is a 3M filter Model usf
  • kd7cxg-2 wrote:
    Amazon has the 3M Filtrete Model 3US PS01 for $40.91, it includes the filter head and one filter. I installed one on our MH two years ago. It takes all the sediment and clorine taste out of the water.
    Hope this helps,
    Tom
    Yep, that's the one I replaced the 3M with. The only downside is it doesn't bypass with the filter removed for winterizing, so I bought a double female sharkbite and pull the pex and route them together through the double female to bypass it.
    Hope this helps,
    Tom
  • The ones I found were over $60 so I switched out the unit to a Filtrete.
  • I do. I use the Hydrolife filter. What model you order depends on whether you have quick disconnects or screw on.
