Speedy921's avatar
Speedy921
Water heater ?
On my old coach there was a switch in the bathroom got the heater. On this new coach (2007) Pace Arrow I cant find such a switch.
  • Your two switches for gas and electric should be under the sink on a panel you can see easily.
  • 2007 Atwood would have electric & gas switches on one panel with a fault light
    2007 Suburban would have gas with fault light & electric in the outside compartment (lower left corner)....COULD have an add'l electric switch inside IF RV MFG added one. If so it could be on range hood, face panel of kitchen cabinets, on the wall, with the gas one----just about anywhere and it would be in series with the outside OEM one (both have to be ON for electric to work) IF RV MFG added one!
    2007 Pace Arrow.......ATWOOD WH
  • My Atwood is gas only with heater exchange. There is 1 switch for the gas. I would check with the mfr. Are you in Dunnellon FLA? A friend of mine lives there & I usually visit.
  • wa8yxm's avatar
    wa8yxm
    Atwood Water heaters typically have two switches side by side Gas and electric
    Surburan the electric switch can be hard to find. Sometimes it is outside on the water heater itself or so I'm told.
