Water Pump issue
psmoore
Was just filling the fresh water and opening the valves to run the water through. I have about 1/2 filled with water so plenty of water. The pump is running I can hear it, but no water at any faucet. I can still see antifreeze in the lines too. Could the pump be running and bad? Thanks. Is it tough to replace a water pump?
Paul and Susan - 4 kids
2001 Winnebago Brave 35C
16 REPLIES 16
Old-Biscuit
Also if you have a 'winterizing' vale it needs to be closed
Turn pump ON
Open nearest faucet HOT side and leave open to fill water heater tank and expel air from system
(Provided WH Tank Bypass is closed ---cold in open, hot out open (if equipped)
wolfe10
On many coaches you have to CLOSE the water fill valve or the pump just recirculates back to the tank.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
