mustex's avatar
mustex
Water pump issues
Hi,
My water pump has stopped working.
It was going one minute and not the next.
Does anyone have any clever ideas? Is there a fuse somewhere?
Cheers
  • So my pump has given up I think. I tested the wires right by the pump and it's definitely getting power to the unit. Thoughts?
    When replacing the pump do I need To get a certain type or can I just use one that fits the pump fittings? I'd like to spend as little As possible as I'm selling The rv soon.
  • Old-Biscuit wrote:
    Hard to say. Different spots for different RV's---MH, TT, FW etc.
    Should be inside the panel where converter is....small panel with a vent for fan
    Post what RV you have and someone with same/similar might chime in
    Sorry, I thought that detail was in my signature.
    I have a 1993 holiday rambler vactioner
  • Hard to say. Different spots for different RV's---MH, TT, FW etc.
    Yes there is a fuse.
    One of them in the DC Distribution panel...probably unmarked(AC/converter panel)
    Don't just look at them..you will need to remove and inspect OR if you have a tester check across the top of fuse.
    Some panels even have a red light that comes on when fuse is bad
    Thanks,
    Where would I find the DC panel?
  • Yes there is a fuse.
