aintnothin's avatar
aintnothin
what adhesives
I'm replacing my slideout covers and when I removed the one for the livingroom/dining area slide, I notice that the fiberglass, where the channel is on the coach, (not the slide itself), has pulled away a little. What adhesive or sealant should I use to fix this? Would liquid nails be ok?
  • That would be some delamination starting. You can toss some glue in there but don't expect great results. Having said that, with the screws going back in it might do a decent job. Just be 100% sure there is no place for any leaks to happen. Chances are some moisture got in there somehow, you need to be sure it doesn't happen again.
  • For a permanent fix, I would use 3M 5200 which is available in regular and fast curing types. Available in marine stores, Amazon and many other places.
