โOct-18-2007 03:40 PM
โJan-25-2009 05:19 PM
ronfisherman wrote:Since I only have to go to 65 psi I don't believe that it'll be a problem.
It works great. Takes a little while to get the last 5 psi in my 95 psi tires. That makes the screw on inflation connector a plus with the pump.
โJan-25-2009 12:31 PM
PR Connection wrote:Calisdad wrote:
Also put that shiny bubble insulation on the inside of the engine dog house. Just cut to fit then use spray adhesive. Tape and/or clamp insulation in place until adhesive sets. Really cuts the sound and heat down.
That stuff is not high temp rated and will probably melt when the weather is hot ..... might even cause a fire. Try using a heat gun on it and see what happens ..... it just shrivles up
JMO
Dan
โJan-25-2009 02:28 AM
โJan-24-2009 05:39 PM
โJan-24-2009 02:40 AM
โJan-23-2009 10:31 PM
โJan-23-2009 12:40 PM
Calisdad wrote:
Fixed the exhaust leak in my Tioga. The last bolt on the right exhaust manifold was broken (Ford 360). I was able to drill it out and retap the hole with the help of a right angle drill and a mirror. Closed the .013 gap down to .002 then put 2 coats of high temp 'ThermoSteel' over the remainder.
โJan-23-2009 11:49 AM
โJan-17-2009 06:21 AM
โJan-17-2009 01:46 AM
โJan-16-2009 05:18 PM
โJan-16-2009 04:55 PM
โJan-15-2009 03:27 AM
โJan-14-2009 05:58 PM
โJan-14-2009 03:51 PM
