โOct-18-2007 03:40 PM
โNov-05-2015 08:32 AM
โNov-04-2015 01:23 PM
โOct-31-2015 06:29 PM
โOct-31-2015 10:46 AM
โOct-29-2015 08:37 AM
โOct-22-2015 08:37 AM
โOct-21-2015 05:46 PM
โOct-21-2015 08:51 AM
โOct-16-2015 09:23 AM
โOct-15-2015 12:16 PM
klutchdust wrote:Thanks for the reply. Most of mine will still be tacky, so that is good. The part that is gone I will do as you did and clean it with acetone. I am thinking of using a wallpaper roller to be sure it is pressed down good. Thanks again for the reply and safe travels to you.Kit Carson wrote:klutchdust wrote:Klutchdust, I have ordered the anti-skid mat to replace on my MH. Question....did you remove the sticky residue before installing the new mat? I should be getting my part in the next couple of days and will be doing the replacing.
Replacing non-skid on running boards, in doing so I located a loose bracket /splash guard that I believe is the source of an
annoying occasional rattle. Always sounded like it was from under the dash on the drivers side. Going to silicone between the
guard and where it mounts and then go one size larger with the mounting screws and adding flat washers with rubber seals on them.
Well, when I got the coach the existing non-skid was removing itself a little at a time. I pulled it off, cleaned the area with acetone. If the adhesive is clean and still
tacky i see no reason to remove it . Mine was mostly gone already and some of it had dirt in it.
โOct-15-2015 08:09 AM
โOct-14-2015 01:04 PM
โOct-14-2015 11:29 AM
โOct-14-2015 10:03 AM
โOct-13-2015 03:55 PM
