Baja_Man
Jul 02, 2016Explorer
What is this refer drain hose part called?
This white hose (see pics) is the hose that travels from inside my refer (the inside water catch pan that runs underneath the inside condenser has a white drain hose at one end), out the back, and ends in the small black colored catch pan. I believe it is for condensation from condenser inside refer.
Can someone tell me the name of the small black part on the end of the white hose and how water leaks out of it? Why is it so restrictive? I'm assuming there is s pin size hole in center, but I can't see it.
I am thinking of mounting small fans inside refer (on condenser) and routing wires out through this drain hose. I would need to remove the small black fitting to allow wires to exit. I prefer to do this so I can run a separate 12V lead instead of using the refer light power and potentially causing a short in refer circuit board.
