What octane gas to use
malojeer
The 07 Gulfstream BT Cruiser we recently bought has a chevy 6 litre engine. The check engine light started coming on after about 2 hours on every trip we've taken . I plugged my code reader in and said using incorrect fuel. I was using 87 octane, so I erased code and filled up with 89 octane and check engine light did not come back on coming home over 3 hrs away. Has anybody else had this happen? The chevy owners manual mentions 87 or higher so didn't think it would matter running 87 octane. Do I have an underlying problem that is causing me to have to run higher octane fuel?
21 REPLIES 21
AJBert
Have a compression test done on all cylinders and compare to what the compression should be. If there is carbon build up in the cylinder heads this would cause knock with 87 octane and would throw a code like you got.
i
If this is your problem, I'm sure the dealership, if you brought it there, would recommend pulling the heads to clean everything up. That would fix the problem but would cost you big $$$$$$$. Get a can of SeaFoam and run it through the intake using the brake booster vacuum line. You can look this up on the internet. The SeaFoam will break down the carbon without pulling the heads.
I've never heard of Cataclean nor the slightly clogged cat causing this kind of problem but if you trust your mechanic then give it a try. If that doesn't do the trick get the compression test done and go from there.
samven1
I dont know how many miles you have or how often you run a full tank through but you may have gotten bad gas with excess water or if you leave the RV sit with a partially filled tank and no gas treatment, condensation can accumulate and either turn the gas bad or settle in the bottom and then mix when you start moving.
I always put Starbrite marine gas treatment in the last fill up just before I get home if I know I wont be travelling for more than a month.
Sam
03 Dodge Ram 1500 QC LB Hemi
2015 Four Winds 22E Chevy
PSW
I had this problem once on a previously owned rig with the Chevy 6L.
I had bought some of that rotgut 85 octane in NM at higher altitude because that was all they had and I was out in the boonies. When we got closer to home (Oklahoma) the light came on. Now, that is an altitude change of about six thousand feet decrease. I filled up with good old Oklahoma purchased 89 octane pure gas (about a 1/4 of a tank of the 85 was still in the tank) and that was the end of the problem. The engine was cutting out a bit above 60 mph. The problem stopped within five miles and never occurred again.
Now, this forum has repeatedly educated me on the fact that lower octanes at higher elevations are just fine. I only know what happened to me. Normally, I always filled this rig with 87 octane containing ethanol and never had a problem the entire time we had the rig. I just always assumed that when I mixed the 85 and 89 pure I made an acceptable fuel for that tankful. And no, the gas cap was tight and never created a problem. That is, however, a very normal source of problems like this one.
Paul
PSW
2013 Phoenix Cruiser 2350
2014 Jeep Cherokee behind it
and a 2007 Roadtrek 210P for touring
mlts22
If you haven't already, I'd recommend dumping some gas preservative in the tank, like Sta-Bil or Star-Tron.
malojeer
I get 13 mpg to 13&1/2 it's only 22 ft long and driving around 60 mph. My job makes it difficult to go camping more than once a month. So it will sit until April.
pconroy328
Wow - to take my tank from full to 1/4 seems like all I have to do is drive it around the block once or twice. ๐Ÿ™‚
9 MPG.
malojeer
Friend says the catalytic converter is a little dirty and said use Mr Gasket Cataclean exhaust treatment. Use 1or 2 times.I read the reviews and they seem to be mostly positive so I will try it. The problem I have now is my fuel tank is full and will have to get the tank below 1/4 so it will be awhile before I get to try this treatment.
malojeer
Yes I got the message incorrect fuel. I don't remember the code but if it comes back up I will let you know. The friend said he will put their diagnostic machine on it but since I erased the code I will wait for the check engine light to come back on. I will keep ya'll posted.
pconroy328
malojeer wrote:
The gas cap is brand new. I always make sure of the fuel grade I use. I wish it was simple solutions y'all mentioned but I've been told I'm snake bit. I probably consult a friend of mine who works for a dealership. Thanks for all the help
Ok - but you're hearing from us that have the same engine and run on the lower octane gas with no problems.
pauldub
Did you really get a code that says you're using the wrong fuel? What's the code?
malojeer
maillemaker
My 1990 Winnebago Warrior definitely prefers 89 octane. It will knock under load with 87.
Steve
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
IAMICHABOD
Is there any chance that you fueled up with E85?
From what I have read on other forums the 6.0 that is not a flex fuel rated engine may throw a code. I believe that they started in 2012.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
ksg5000
Loose gas cap or gas cap with hairline crack will trigger that kind of code.
Kevin
