Where's the bloody switch?
Gonzo42
I'm currently inspecting the MH that my veteran's help org has. The batteries were dead, but now I have them charged.
Can anyone tell me where the battery disconnect switch is in a 2005 Fleetwood Expedition 34H?
I have a ton on manuals which mention it but don't show it in any diagram or even mention the general area.
Thanx for the help.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
7 REPLIES 7
Gonzo42
Found it ! Its located on the control panel above the co-pilot's seat, above the windshield. Inside the compartment with the glass door.
Thanx to everyone for the ideas.
discovery4us
Our friends 04' has a dial disconnect bolted to the radiator support accessible through the rear vented access door. May be the same on the 05'. Also there is a switch next to the door on the left as you enter (salesman switch).
Gonzo42
True, I don't expect the batteries to last a year from now. Meanwhile I can now check out the whole machine to verify all functional equipment.
thanx for the ideas.
Canadian_Rainbi
And if the batteries were really dead or discharged for any time they may not recover very well.
Germania
On my 2005 Fleetwood Fiesta they are behind a panel over the entry door Good Luck
Trackrig
On my Fleetwood 2005 Excursion 39S, there are switches over the passengers windshield and then the booster switch by the driver's elbow. The Discovery is the same. On those two, there aren't any other factory battery switches.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
rgatijnet1
Check in the basement compartments. My disconnect for the chassis batteries is up front in the basement. For the house batteries it is in the same compartment with the batteries.
