Olddud
Aug 01, 2018Explorer
mkstn1400 wrote:
We just placed an order for a new Tiffin Wayferer. Nicely laid out and built with quality materials. It handled great... much better than the Winnebago even though they are both on the Mercedes Sprinter. Go figure.
Might want to check the OCCC on the unit. Sprinter RVs are very limited on that important item. If there is one on a lot near you, look inside the door or wherever they have the OCCC stated, and hopefully it isn't 900 lbs. We have a Winnebago unit with 1350 OCCC, which is tight for two and not good for 4. I suspect Tiffin has much in the way of upgraded items, which probably means more weight. Options add weight also, usually.
Good luck!
38,707 PostsLatest Activity: Feb 18, 2025
