- BillofPAExplorerThere are probably springs on the one side of screen. Push screen towards that side (compress springs) and it'll come out.
- philandterriExplorerThese windows are not sliders, they operate up and down.
- FIRE_UPExplorer
philandterri wrote:
2006 Bounder 32W, how do you remove screens in the bedroom slideout.
It depends on who made the window package. On some, like ours in our '04 Itasca Horizon 36GD, there's a small procedure to get them out.
1. Slide the screen all the way open, same direction as the slider glass.
2. Look down and lift up on the plastic, upside down U-channel that the screen slides on. That channel is removable. Remove it.
3. Slide the screen back to the closed position and, lift it out. It will easily come out due to the added clearance created by removing the channel it rides on.
Now, are yours built the same way, not sure but, could be.
Scott - doxiemom11Explorer IIOurs -- open a little, then lift up on it while tilting the bottom inward toward you.
- BigRabbitManExplorerMost likely, lift up and remove.
About Motorhome Group
38,768 PostsLatest Activity: Dec 18, 2017
