Winnie/Itasca coach vs chassis battery wiring notes
spotrot
In case it is of use to others, this is how my 2008 30B was wired - and this was not in the owners manual:
When the engine is running, the alternator only charges the chassis battery -- it does not charge the coach batteries.
Also, when the RV is plugged into 120v, its inverter only charges the coach batteries; it does not charge the chassis battery.
Likewise the Onan generator only charges the coach batteries.
(I installed a switch to jumper the coach and chassis batteries when needed so that all batteries will charge when driving or when plugged in at a campground)
Other Notes:
The dash cig lighter outlet connects to the coach batteries.
The steps connect to the chassis battery.
10 REPLIES 10
dougrainer
ALL Winne/Itascas charge the Coach batteries from the chassis Alternator. This is from the 2008 Winne/Itasca owners manual. So, the OP needs to find out what part of his charging system is bad. Doug "The house batteries can also provide
emergency power to start the engine if the chassis
battery is discharged. (See “Battery Boost
Switch” or “Aux Start Switch”).
House batteries are automatically charged by
the chassis alternator while the engine is running".
FIRE_UP
MrWizard wrote:
its Normal for the alternator to charge EVERYTHING, either thru diode base isolator or heavy duty charge relay (any MH that does not charge the house from the alternator has a problem that needs to be tracked down and fixed)
it is also very common for the 120v charging circuits to only charge the house side RV batteries
some MH's have a Bi-directional charging for all batteries from either source
but it is NOT common
This answer ought to be posted, at the beginning of ALL battery problem/issues/questions whether it pertains to the individual question(s) or not. Very, very good answer.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
pianotuna
Nomad III
Nomad III
Hi,
I purchased mine while in USA.
Canadian Rainbirds wrote:
Don; Who was your Canadian source for Amp-L-Start? I can't find anyone who carries them. I just lost my second Xantrex Echo Charger to moisture/fumes. (On the battery comp door)
Regards, Don
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
Canadian_Rainbi
pianotuna
Nomad III
Nomad III
As I wished to maintain the starter battery I added a trik-l-start. This allows any charging done to the house batteries to flow to the starter battery.
There is now a higher amperage alternative called an amp-l-start.
Both of the devices are diode based and do show voltage drop.
Regards, Don
Canadian_Rainbi
Other Notes:
My highlight above; this is NOT normal. Probably a failed diode or solenoid.
To charge chassis batteries from gen, shore power, solar, use a charger that charges from the house batteries when the the house batteries are at an adequate voltage. For example, our Xantrex Echo Charger charges the chassis batteries when: The chassis batteries are 0.5V to 1.0V less than the house batteries AND the house batteries are 13.0V or greater.
Pangaea_Ron
My 2008 Itasca SunCruiser also was not wired to charge the starting/chassis battery when plugged into 120vAC or from the generator (verified with Itasca technician when I purchased it). I added a "smart" charger to do that.
It's amazing where they choose to save money.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
pianotuna
Nomad III
Nomad III
Hi,
Check for a blown fuse in the engine compartment fuse box. Mine blew regularly so I had it replaced with an automatic circuit breaker.
The OEM charging solenoid had burned contacts within a year--I replaced it with a continuous duty with a much higher amp rating.
Regards, Don
wolfe10
Never heard of a coach that did not charge BOTH battery banks from the alternator.
Look for either a solenoid-based battery isolator or diode-based battery isolator.
Just trace the heave gauge cable from the B+ terminal of the alternator.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
