Aug-12-2021 05:28 AM
Aug-12-2021 03:57 PM
pianotuna wrote:
I fill my tank with premium for the last trip of the season and add the appropriate amount of seafoam.
I have a modes solar panel system that maintains the house and chassis battery.
Aug-12-2021 03:53 PM
Aug-12-2021 03:49 PM
Aug-12-2021 03:18 PM
jdc1 wrote:
What do car dealers do with the cars sitting on their lots all winter? Probably disconnect the battery and put it in warm storage on a trickle charger. And nothing else.
Aug-12-2021 08:11 AM
Aug-12-2021 07:10 AM
Aug-12-2021 07:05 AM
Aug-12-2021 07:02 AM
Aug-12-2021 06:48 AM
Cardinals wrote:
1. Is there any recommendation on how much fuel to leave in the tank when I put it away for winter? Full/Half? Full
2. Is there an additive I should add to the fuel tank prior to storage. If yes, what do you recommend? Add Stabil to the tank
3. My plan is to start the engine of the MH at least once or twice a month. It is stored about 5 minutes from our home. Is that too little to too much? Once a month should be more than enough. Let it run until it's up to operating temperature
4. I also plan on testing the generator at least once a month...thoughts. Run the generator at least once a month. Make sure you run it under a partial load. A 1500 watt electric heater works well.
5. I will winterize the unit and prep it for storage.
Thank you for your anticipated comments and assistance.
