Johno02
Oct 12, 2015Explorer
Probably wiring to the pedestal. The wiring run to the pedestal from wherever is probably a lot longer than your cords, and may have several others pulling power from it also. Also, like others said, check and clean blades on you plugs. Also, check you plugs and cord ends for overheating. With that much voltage drop, something is getting hot somewhere. Also, check voltage at the pedestal. If the drop is there, it is a park problem.
38,705 PostsLatest Activity: Jan 24, 2025
